PXI Chassis Appears in NI MAX As PXI System (Unidentified)
Updated Apr 5, 2023
  • PXI Chassis
My PXI chassis does not appear in Measurement & Automation Explorer (MAX) how I expect it to.
There is an entry for PXI System (Unidentified). Is this my chassis? How do I get it to appear correctly?
Right-click on the PXI System and choose to Identify as >> External PC to select your particular controller and chassis.
You may need to reboot your computer and then Windows should find the devices automatically. This only applies to PXI specific chassis, not PXI Express chassis.
If you are using MAX 2.x or earlier, PXI Chassis, themselves, will not show up unless you are using a Combo Chassis, in which case there is an SCXI portion that you can add manually.
