Enable Z Indexing in NI-DAQmx
Updated May 3, 2018
  • PXI-8431/2
I am using an encoder in my application and I would like to enable Z indexing.  How do I do this?
To enable Z indexing follow these steps:
  1. Place a DAQmx Create Channel node on your block diagram.
  2. Configure the node as CI Angular Encoder (Counter Input>>Position>>Angular Encoder).
  3. Wire a True Constant into the node's Z Axis Enable input.
An example of this implementation can be found in this DAQmx-Measure Angular Position document.
