This list of source control providers is
not intended to list all compatible providers. If a provider is not listed, that provider may or may not integrate with LabVIEW 8.x or later. Typically, source control providers that are compatible with the Microsoft Visual Studio .NET development environment should also integrate with the LabVIEW 8.x PDS.
- SourceOffsite was tested and proven not to be compatible with LabVIEW 8.x or later. The manufacturer does not have plans to evaluate this compatibility issue.
- Microsoft Team System was tested with LabVIEW 8.5.
- Currently, ionForge Evolution version 2.8 and later works with LabVIEW. Depending on the version of ionForge Evolution you use, enable IDE Integration for ionForge Evolution to show up as one of the SCC Providers in LabVIEW. To enable IDE Integration, open ionForge Evolution and select Make Evolution your default source code provider. (Enable IDE Integration) within View»Options. Close and open LabVIEW.
- With MKS Source Integrity Client 2005,
Error -2901 has been reported. The error description is Error occurred at prefPage_Source Control.vi Possible reason(s): LabVIEW: An error occurred during source control provider initialization. If you experience this error, backup the Windows Registry, and then set the dllName key, located atHKEY_LOCAL_MACHINE\SOFTWARE\Mortice Kern Systems\Integrations\SCC\IDEs\National Instruments LabVIEW to use base. - LabVIEW by itself does not have this feature, hence we recommend the SCC software mentioned above.
- With PTC/MKS Integrity, enable Visual Studio Integration in the PTC/MKS configuration utility that came with the source control software. If this does not work, try running the configuration utility as administrator.
For more information on source control in LabVIEW, please refer to
Software Configuration Management and LabVIEW.
