Error 65672 Using a NI 9469 in LabVIEW FPGA
Updated Jan 2, 2018
  • NI-9469
  • NI-9775
  • LabVIEW FPGA Module
  • NI-RIO
Programming Language
  • LabVIEW G
  • I'm using the Set Internal Timebase Frequency invoke node
  • On run-time I get error 65672
  • I use the explain error tool (Help»Explain Error...) to learn more
  • Explain error shows me the message below​
  • As the error implies we need to verify that all the modules importing this timebase support that frequency
  • If the frequency is not supported we should try using a different frequency
  • To check frequency you can look at the modules datasheet
  • For example the 9775 datasheet specifies the Internal master timebase as 12.8 MHz which is why 13.1072 MHz throws an error with the code below
