Undirected Tunnel Error With Stacked Sequence Structure
Updated Jul 8, 2019
  • LabVIEW Base
  • LabVIEW Professional
When I run my code, I receive an  Undirected Tunnel Error. LabVIEW identifies a stacked sequence structure on my block diagram as the source of the error. How do I fix this error?
There are a few different steps you can try to fix this error:
  • If a source is connected on both sides of the structure or no source is connected, the tunnel cannot decide the direction of dataflow. Verify that every case in your stacked sequence structure is fully wired, and that a source is never connected on both side of the structure. The LabVIEW 2018 Help manual has more detailed information on this case.
  • Remove any broken wires in your VI by selecting Edit»Remove Broken Wires or by pressing <Ctrl-B>
  • If you have tried both of the previous steps and are still seeing this error, try replacing your stacked sequence structure with a flat sequence structure. Right-click the stacked sequence structure and select Replace»Replace with Flat Sequence to resolve the error.
A tunnel serves as either an input or an output from a structure. If a source is connected on both sides of the structure or no source is connected, the tunnel cannot decide the direction of dataflow.
