The file that contains these aliases is
visaconf.ini, and its location depends on both your operating system and the version of NI MAX that you are using. To determine your version of MAX, open the program and go to
Help»About. The splash screen should display the version.
NI MAX 4.2 and later: The file containing VISA aliases is located in the Windows data directories.
Windows XP and earlier:
C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa\visaconf.ini Windows Vista and later:
C:\ProgramData\National Instruments\NIvisa\visaconf.iniNote: The ProgramData folder is hidden by default. See
Microsoft's support page on how to show hidden files.
If you need to modify your aliases, you can use the VISA Alias Utility in MAX. You can access this utility in MAX by selecting
Tools»NI-VISA»VISA Options and selecting
Aliases from the
My System list. This utility will allow you to view and modify all the VISA aliases stored on your computer. A screen shot of the utility is shown below:
For MAX versions earlier than 4.2:Windows XP and earlier:
C:\VXIPNP\WinNT\NIvisa\visaconf.iniNote: You can access aliases directly in your system by browsing to a configuration file called
visaconf.ini. This file can typically be found in the following location:
Windows Vista or later:
C:\ProgramData\National Instruments\NIvisa\visaconf.iniWindows XP:
C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa\visaconf.iniWindows 2000/NT:
C:\VXIPNP\WinNT\NIvisa\visaconf.iniPharLap ETS:
ni-rt\system\vxipnp\WinNT\nivisa\visaconf.iniNI Linux Real-Time:
/usr/local/vxipnp/linux/NIvisa/visaconf.ini
