You can configure the termination character for VISA Serial Read VIs. You can use the End Mode for Reads property (also known as ASRL End In) to configure how VISA Read will stop reading characters.
In order to configure the termination character for serial reads you must set the End Mode for Reads property or the VISA_ATTR_ASRL_END_IN attribute.
