Using NI 9694 J10 and J11 Connectors
Updated Dec 10, 2018
  • sbRIO-9694
Other
Hardware: Reconfigurable I/O (RIO) >> NI Single-Board RIO
I would like to connect a ribbon cable to the J10 and J11 connectors on the NI 9694 RIO Mezzanine Card Breakout. What is the pin spacing for these connectors? What connector should I use to interface with the J10 and J11 connectors?
The pin spacing for the J10 and J11 connectors is 0.100". National Instruments recommends the SAMTEC TSW-116-07-S-D connector to populate these connections.
