Connecting to a sbRIO-9626/9627 using a 50-pin IDC Header Connector
Updated Jan 11, 2023
  • sbRIO-9626
  • sbRIO-9627
Other
Hardware: Reconfigurable I/O (RIO) >> NI Single-Board RIO>>sbRIO-9626
Is there a breakout board or terminal block that I can use to connect to the 50-pin IDC header of the sbRIO-9626 or sbRIO-9627?
Yes, the 2 mm IDC Connector Breakout Kit (part number 784507-01), now called the sbRIO Breakout Box can be used to breakout the 50-pin IDC header on the sbRIO-9626 and the sbRIO-9627.  The breakout uses screw terminals so free leads can be connected to the IDC pins.
Often, custom PCBs are created for the 50-pin IDC header, in which case the NI Single-Board RIO 50 pin Ribbon Cable with IDC Headers (part number 154041-12) can be used to connect the custom PCB with the 50-pin IDC header on the sbRIO.
