Wrong Simulation Output in Multisim When Using ELVISmx Instruments
Updated Dec 6, 2018
  • Multisim Full
  • Multisim Base
  • NI-ELVISmx
I have a circuit including ELVISmx instruments and it gives the right output using Interactive Simulation. However, if I try to run other analysis type, for example a Parameter Sweep, the output is incorrect.
ELVISmx instruments are only supported on Interactive Simulation and will not provide an output or perform a reading on any other analysis type. If you need to perform an analysis on the circuit, replicate the circuit by replacing the ELVISmx Instruments for the Virtual Instruments provided as part of Multisim in the Instruments Toolbar.
Refer to the Instruments Toolbar section from theĀ Multisim User Guide for more information about the available Virtual Instruments.
