NI CAN/LIN/FlexRay/Automotive Ethernet Device Power Supply Requirements
Updated Jun 4, 2024
  • CAN Interface Device
  • Vehicle Multiprotocol Interface Device
  • Transceiver Cable
  • LIN Interface Device
  • FlexRay Interface Device
  • Automotive Ethernet Interface Device
I have a NI-CAN or NI-XNET device that I'm using, but I'm not sure whether I need an external power supply or not. Is there a list of which devices are internally or externally powered?
CAN Devices:
Device SeriesHigh-Speed (HS)Low-Speed (LS)Single Wire (SW)Software Selectable (XS)
NI-XNETPCIPCI-8512
Internal
PCI-8511
Internal
PCI-8513
External (8-18V)
PCI-8513
Mode Dependent
PXIPXI-8512
Internal
PXI-8511
Internal
PXI-8513
External (8-18V)
PXI-8513
Mode Dependent
USBUSB-8502
Internal
USB-8501
Internal
XX
C SeriesNI 9862
External (9-30V)
NI 9861
External (9-30V)
XX
Transceiver
Cables
TRC-8542/8543
Internal
TRC-8543
External (9-30V)
XX
NI-CANPCI-CANPCI-CAN
Internal
PCI-CAN/LS
Internal
PCI-CAN/SW
External (9-18V)
PCI-CAN/XS
Mode Dependent
PCMCIA-CANPCMCIA-CAN/HS
PCMCIA-CAN/HS
Internal
PCMCIA-CAN/LS
Internal
PCMCIA-CAN/SW
External (8-18V)
X
PXI-846xPXI-8461
Internal
PXI-8460
Internal
PXI-8463
External (8-18V)
PXI-8464
Mode Dependent
USB-CANUSB-8473
Internal
USB-8472
Internal
XX
NI-RIONI 9853 Port 0:
Internal
NI 9852 Port 0:
External (8-36V)
XX
NI 9853 Port 1:
External (8-25V)
NI 9852 Port 1:
External (8-36V)
XX
LIN Devices:
Device SeriesLINPower
NI-XNETPCIPCI-8516External (8-18V)
PXIPXI-8516
USBUSB-8506
C SeriesNI 9866
Transceiver
Cables
TRC-8546
NI-CANUSB-CANUSB-8476External (8-18V)
FlexRay Devices:
Device SeriesFlexRayPower
NI-XNETPCIPCI-8517Internal
PXIPXI-8517
Automotive Ethernet Devices:
NI-XNET Automotive Ethernet Devices (PXI-8521, PCI-8521, IVN-8561) do not require any external bus power.
  • When using XNET transceiver cables with an NI 9860 C series module, the NI 9860 itself must also be powered externally (9-30V), in addition to bus power requirements shown in the table. Details can be found in the NI 9860 Getting Started Guide.
