Use Keysight (HP Agilent) GPIB Devices with NI Software
Updated Jan 14, 2020
  • GPIB-USB
  • GPIB-USB-HS
  • NI-VISA
  • NI-488.2
  • GPIB Software
Other
  • Agilent
  • I have a Keysight (HP Agilent) GPIB instrument and I want to use it with NI Measurement & Automation Explorer (MAX) or LabVIEW.
  • My Keysight instrument is not being recognized in NI Measurement & Automation Explorer (NI MAX), but it is detected by Windows Devices and Interfaces, and Keysight software.
  • I can't connect with my Keysight instrument using NI VISA and NI Measurement & Automation Explorer (NI MAX).
In order to use the NI-VISA drivers and both the Keysight (HP Agilent) and NI GPIB devices, you will need to enable:
  • NIVISATulip.dll
  • NI 488.2 from within the Keysight (or Agilent) libraries
Complete the steps in the following document to enable NIVISATulip.dll: Using Both NI GPIB and Keysight HPIB Controllers in the Same System
Complete the following steps to enable NI 488.2, depending on the Connection Expert Version you have.
Note: During Version 17.x, the software name changed from Agilent Connection Expert to Keysight Connection Expert.
  • Keysight Connection Expert 17.x steps:
1. Under the Settings tab, select Options»Keysight 488 Options.
2. Check Enable Keysight GPIB cards for 488 programs.
  • Agilent Connection Expert 16.x and 15.x steps:
1. Select Tools»Agilent 488 from the pulldown menu.
2. Select the Agilent 488 Options tab.
3. Check Enable Agilent GPIB cards for 488 programs.
  • Agilent Connection Expert 14.x steps:
1. Under the Tools»Options Agilent 488 Options from the pulldown menu.
2. Check Enable Agilent GPIB cards for 488 programs.
This method only applies to Keysight/Agilent/HP's IEEE 488 interface cards.
If you are unable to communicate with your device and a VISA test panel in NI MAX fails, check the physical connections. If you are using a Keysight instrument with a NI GPIB-USB-HS, try adding a GPIB connector between the instrument and GPIB-USB-HS.
If these steps do not work then please contact National Instruments Technical Support.
