이 내용은 고객님의 설정 언어로 확인할 수 없습니다
Combining a User-Created .ini File with LabVIEW.ini for Distribution
Updated Jan 13, 2023
  • LabVIEW Base
  • LabVIEW Professional
I have a LabVIEW VI that I have built into an application. By default, LabVIEW creates an .𝚒𝚗𝚒 file which has the same name as the executable 𝙴𝚡𝚎𝚌𝚞𝚝𝚊𝚋𝚕𝚎 𝙽𝚊𝚖𝚎.𝚒𝚗𝚒 to store the LabVIEW environmental settings for distribution, as shown in the photo below. I also have my own custom configuration file, which I would like to combine with the default LabVIEW .𝚒𝚗𝚒 file. Is there a method for combining the two files?
You can use Application Builder to combine your custom .𝚒𝚗𝚒 file with the default 𝙴𝚡𝚎𝚌𝚞𝚝𝚊𝚋𝚕𝚎 𝙽𝚊𝚖𝚎.𝚒𝚗𝚒 file into a single .𝚒𝚗𝚒 file. You must have your custom .𝚒𝚗𝚒 file saved in the project in order to add it, as shown in the photo below.
Next, follow the steps below to accomplish combining the .𝚒𝚗𝚒 files.
  1. Right-click on your executable build specification and select Properties.
  2. In the properties window, select the Advanced category.
  3. In the configuration file in project section:
3.1. For LabVIEW 2010 and later: Check Use Custom Configuration file
3.2 Prior to LabVIEW 2010: Uncheck the box next to Use the default LabVIEW Configuration file (LabVIEW.ini)
4. In the Select Project File dialog, either select the custom .𝚒𝚗𝚒 file if it is in your project or click Add... to browse for it.
5. If you are using Configuration File I/O VIs from the palette below:
Ensure that all of your configuration file accesses within your application point to the new location which is at the same level as the executable, as shown below:
6. Rebuild the application.
7. Note the name of the 𝙴𝚡𝚎𝚌𝚞𝚝𝚊𝚋𝚕𝚎 𝙽𝚊𝚖𝚎.𝚒𝚗𝚒 file generated from the build. You might need to rename the file generated to match the name of the .𝚒𝚗𝚒 file referenced by your LabVIEW code in the 𝙾𝚙𝚎𝚗 𝙲𝚘𝚗𝚏𝚒𝚐 𝙳𝚊𝚝𝚊.𝚟𝚒 as shown above. After renaming the 𝙴𝚡𝚎𝚌𝚞𝚝𝚊𝚋𝚕𝚎 𝙽𝚊𝚖𝚎.𝚒𝚗𝚒 file generated, the final result should look like this:
On the deployed machine, the custom .𝚒𝚗𝚒 file and the executable must be located at the same level in the directory structure because this is the default location where LabVIEW searches for the .𝚒𝚗𝚒. If LabVIEW cannot find it in this location it will auto-generate a new .𝚒𝚗𝚒 file and your environmental settings will be lost.
