To fix this issue, perform the following steps:
- Browse to Program Files (x86)\National Instruments\Shared\NIUninstaller
- Run InstallValidator.exe
- Press OK on the following dialog:
If the NI Uninstaller directory is missing, you can copy it to your computer from another machine with LabVIEW. This will give you access to InstallValidator.exe.
