NI Software Not Appearing in Uninstall a Program
Updated Jan 10, 2019
I want to modify, repair or uninstall my National Instruments software but the National Instruments Software category does not appear in the Window's Uninstall a program list. When I navigate to Control Panel >> Programs >> Uninstall a program,  I do not see National Instruments Software.
To fix this issue, perform the following steps:
  1. Browse to Program Files (x86)\National Instruments\Shared\NIUninstaller
  2. Run InstallValidator.exe
  3. Press OK on the following dialog:
If the NI Uninstaller directory is missing, you can copy it to your computer from another machine with LabVIEW. This will give you access to InstallValidator.exe.
The issue may occur if you:
  1. Install third-party software that includes NI software components
  2. Install NI Software with a setup.exe version earlier than 2.4.1
  3. Remove InstallerValidator.exe from HKEY_LOCL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
  4. Use anti-spyware software that blocks HKEY_LOCL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
  5. Remove registry keys from HKEY_LOCL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
