You can use Application Directory.vi and directly build the desired file's path, as can be seen in the following snippet:
Alternatively, you can use
Current VI's Path in LabVIEW to return the path of the calling VI. Then, by using
Strip Path and
Build Path, you can programmatically construct the file path for the other file. Refer to the following steps for creating code to programmatically set a filepath.
- Place
Current VI's Path on the block diagram. This function can be found in the Functions palette at Programming»File I/O»File Constants.
- Place
Strip Path and Build Path on the block diagram. Both can be found in the Functions palette at Programming»File I/O.
- Wire the diagram as shown below.
