GSDML File for CompactRIO PROFINET Slave Card
Updated Apr 3, 2025
  • cRIO-PN-S
I want to configure my CompactRIO PROFINET Slave module, but I can not find the GSDML file which is necessary to achieve proper communication with the master.
The GSDML file to be imported into your PROFINET IO-Controller configuration tool for the CompactRIO PROFINET module (cRIO-PN-S in short) by KUNBUS GmbH is included in its driver package. The driver is called cRIO PN by KUNBUS GmbH . The most convenient way to install it is through VI Package Manager using this direct link.
After installation is finished, the GSDML file is available on your computer in C:\Users\Public\Documents\KUNBUS GmbH\GSDML similar. The file's name format is GSDML-V[x.x]-Kunbus-cRIO PN-[yyyymmdd].xml.
Additionally, the cRIO PN by KUNBUS GmbH driver installs a Profinet device LabVIEW example project that can be accessed via LabVIEW's Example finder: Open Example Finder in LabVIEW via menu Help » Find Examples, then go to tab Browse, click Browse according to: Directory Structure, and open KUNBUS GmbH » cRIO PNAD » FPGA Bitfiles » CS_cRIO-PN_IO-DeviceExample.lvproj.
