Error -1073807360 When Using BLE Toolkit to Communicate
Updated Jan 12, 2023
  • LabVIEW 2017 Professional
  • NI-VISA
When I use the bluetooth low energy (BLE) functions from the BLE toolkit, and I run my application for anywhere from several minutes to several hours, I get Error -1073807360 at Property Node (arg 8) in VISA Configure Serial Port (Instr).vi. If I stop my program and restart it, it runs again as if nothing happened. My start and scan functions are inside a loop. How do I mitigate this?
Move the start function (as well as other configuration functions) outside the while loop and see if the error persists.
This error can occur if you're repeatedly configuring the bluetooth. Configuration at the beginning of connection should suffice.
