Changing the Default Values in NI WLAN Generation Soft Front Panel
Updated May 3, 2018
  • WLAN Generation Toolkit
Since I have different settings for multiple RF analog signal generators, I would like to modify the soft front panel title and default settings as shown below when starting the NI WLAN Generation Soft Front Panel.
Unfortunately, it is not possible to change the default soft front panel title or default settings at start-up.
However, you can save your customized configuration settings and load the file containing the configuration information in the NI WLAN Generation Soft Front Panel.
To save/load the current configuration file for the NI WLAN Generation Soft Front Panel, click Save/Load as shown below.
This will prevent you from having to configure the settings each time.
Although limited, it is possible to change certain appearance settings such as the font size, and location of the context help by modifying the NI WLAN Generation Soft Front Panel.ini file.
