Setting the Time Zone of a Real-Time Controller
Updated Feb 2, 2026
  • LabVIEW Real-Time Module
  • Phar Lap
This article explains the steps to follow to configure a Real-Time controller's time zone. It includes three different approaches to change the time zone depending on the application, the developer implementations and developer interests.
After following the steps listed in this document, the controller's current time zone can be configured and correct time stamps in graphs, data structures and data logs can be obtained.
By default, the Real-Time controller is set to Coordinated Universal Time (UTC). This can be configured differently using one of the following methods:
  1. Using Measurement & Automation Explorer (MAX).
  2. Modifying the INI file.
  3. Using NI System Configuration APIs.
Select the desired time zone in MAX on the Time Settings tab of the Real-Time target.
Modifying the INI File (for VxWorks or Phar Lap ETS Real-Time Targets only)
The following method is limited to Phar Lab and VxWorks based targets. If the device is running NI Linux RT, please follow the steps listed in NI Linux Real-Time Target Timezone Does Not Match Configured Timezone .
The time zone of a Real-Time controller can also be changed by modifying the RTTarget.TimeZone token in the ni-rt.ini file. The token can be found in the [LVRT] section of the file.
Instructions on obtaining and modifying the INI file can be found below:
  1. Use WebDAV or FTP to copy the ni-rt.ini file from the Real-Time controller to the development computer.
  2. Open the ni-rt.ini file in a text editor (for example Notepad).
  3. At the top of the file, there is a section named [LVRT], which is where the RTTarget.TimeZone token may be found or added.
  4. To change the time zone either add or modify the RTTarget.TimeZone token to the INI file.
    • For example, use INI token RTTarget.TimeZone=CST6CDT to set the controller to the Central United States time zone.
    • Other available INI values are listed in the table below:
      INI Value    Time Zone    UTC Offset
      CUT0GDTCoordinated Universal TimeUTC
      GMT0BSTUnited KingdomUTC
      AZOREST1AZOREDTAzores, Cape Verde    UTC-1
      FALKST2FALKDTFalkland Islands    UTC-2
      GRNLNDST3GRNLNDDTGreenland, East Brazil    UTC-3
      AST4ADTCentral Brazil    UTC-4
      EST5EDTEastern United States, Colombia    UTC-5
      CST6CDTCentral United States, Honduras    UTC-6
      MST7MDTMountain United States    UTC-7
      PST8PDTPacific United States, Yukon    UTC-8
      AST9ADTAlaskaUTC-9
      HST10HDTHawaii, Aleutian Islands    UTC-10
      BST11BDTBering Strait    UTC-11
      NZST-12NZDT    New Zealand    UTC+12
      MET-11METDT    Solomon Islands    UTC+11
      EET-10EETDT    Eastern Australia    UTC+10
      JST-9JSTDT    Japan    UTC+9
      KORST-9KORDT    Korea    UTC+9
      WAUST-8WAUDT    Western Australia    UTC+8
      TAIST-8TAIDT    TaiwanUTC+8
      THAIST-7THAIDT    ThailandUTC+7
      TASHST-6TASHDT    Central Asia    UTC+6
      PAKST-5PAKDT    PakistanUTC+5
      WST-4WDT    Gorki, Central Asia, Oman    UTC+4
      MEST-3MEDT    Turkey    UTC+3
      SAUST-3SAUDT    Saudi Arabia    UTC+3
      WET-2WET    FinlandUTC+2
      USAST-2USADT    South Africa    UTC+2
      NFT-1DFT    NorwayUTC+1
  5. Save the file as ni-rt.ini locally (such as the desktop).
  6. Use WebDAV or FTP to transfer the file back to the Real-Time controller.
  7. Reboot the Real-Time controller.
Note: Linux Real-Time targets support the tz (or Olson) database. The database contains all the needed information about DST settings for specific time zones. The RTTarget.DSTRule INI token cannot be changed to alter DST rules on Linux RT targets.
LabVIEW 2012 Real-Time Module and later:
The LabVIEW 2012 Real-Time Module introduced the NI System Configuration API , which can be used to programmatically set the time zone of a Real-Time Controller using the Set Time VI.
The input Time Zone string for the Set Time VI  needs to be of the form Etc/GMT-X where positive values for X represent hours west of the GMT. For example, Etc\GMT+6 is the equivalent to Central Standard Time in the US. Valid values range from 12 to -13 centered around GMT.
Note: This image is a LabVIEW snippet, which includes LabVIEW code that you can reuse in your project. To use a snippet, right-click the image, save it to your computer, and drag the file onto your LabVIEW diagram.
If the above code snippet is executed on the Real-Time target, the Target parameter must have a value of localhost. Otherwise, Error -2147467263 NI System Configuration: This operation is not implemented for this target or resource will be thrown.
LabVIEW 2011 Real-Time Module and Previous:
The LabVIEW 2011 Real-Time Module and previous Real-Time Modules do not include support for setting a specific time zone. Instead, it is recommended to set the time programmatically using the RT Set Date and Time VI.
Note: VxWorks and Pharlap targets must be restarted for the time zone settings to apply. NI Linux Real-Time targets do not require a restart. Configuring the time zone also activates the daylight saving feature of the controller.
