Can I Save Data From MAX Test Panels?
Updated Oct 7, 2019
Other
NI-MAX
I recorded data in a test panel in Measurement & Automation Explorer (MAX). Can I save or export this data to a log file directly from MAX?
No. The test panels in MAX are designed to verify expected or troubleshoot unexpected behavior.
If your test panels take advantage of any MAX configuration settings such as tasks, channels, and scales, you can export these settings to LabVIEW and then use File I/O VIs to save the data to a log file.
