LabVIEW XY-Graph with Segmented Linear and Logarithmic Axes
Updated Nov 14, 2023
  • LabVIEW Base
  • LabVIEW Professional
Programming Language
  • LabVIEW G
Is it possible to split the x-axis of a XY-Graph into a linear and a logarithmic part?
There is no possibility to scale parts of axes in a different way.
However you can copy your data and display both plots in your graph. Then you can format one x-axis linearly and the other logarithmically.
Displaying Multiple Plots on XY Graphs
The XY graph accepts three data types for displaying multiple plots. The XY graph accepts an array of plots, where a plot is a cluster that contains an x array and a y array.
The XY graph also accepts an array of clusters of plots, where a plot is an array of points. A point is a cluster that contains an value and a y value. The XY graph also accepts an array of clusters of plots, where a plot is an array of complex data, in which the real part is plotted on the x-axis and the imaginary part is plotted on the y-axis.
