National Instruments software can be downloaded from
ni.com/downloads by following the steps below.
Note: If you need to install offline and would like to install using installation/physical media, refer to the
Requesting Physical Media for NI Software Installation page on how to request it.
- Before downloading, register your serial number to your ni.com account. Registering your serial number will ensure that you have access to download the correct software versions connected to your license.
- Locate the specific software download page on our website. You can locate this by searching for the software you need to download at ni.com/downloads or by searching for the specific software name in any search engine. Note: If you are unsure what software to download or what is included with your license, contact National Instruments.
- Once you locate the software download page, make sure to select the correct Version and Edition you need and select Download. An example of what the download page should look like it listed below. Note: This is the LabVIEW specific download page.
- Once the download is completed, run the downloaded file to start the installation and then activate your products with your serial number.
