Archived:NI-FieldPoint and LabVIEW Version Compatibility
Updated Feb 20, 2024
  • FieldPoint (Legacy)
  • NI-FieldPoint
Which NI-FieldPoint driver versions are compatible with my version of LabVIEW?
The following table outlines the different LabVIEW versions supported by NI-FieldPoint drivers
Please note NI dropped support for FieldPoint in 2016. FieldPoint 15.5 is the last release of FieldPoint software. For this reason, you will not be able to use Compact FieldPoint hardware with any LabVIEW version newer than 2015 SP1. If you are using a newer version of LabVIEW than 2015 SP1, you will most likely encounter Error 32800.
