Distributing the LabWindows™/CVI™ Run-Time Module for Linux
Updated May 3, 2018
  • LabWindows/CVI Base
  • LabWindows/CVI Full
  • LabWindows/CVI Run-Time Module for Linux
  • Linux
Do I need to purchase run-time licenses for every LabWindows™/CVI™ Linux application I deploy?
No, you do not need additional deployment licenses for distributing applications that were created using the LabWindows/CVI Run-Time Module for Linux.
The NI LabWindows/CVI Run-Time Module for Linux extends the LabWindows/CVI Development Environment to help developers create high-performance, stable applications on a Windows system and later compile and run these applications on a Linux target, so no license is needed for the deployment machine.
Note: There is no Standard Service Program (SSP) for the LabWindows/CVI Run-Time Module for Linux.
