Feature Weights in Models in Analytics and Machine Learning Toolkit
Updated Jan 10, 2019
  • LabVIEW Analytics and Machine Learning Toolkit
I am using the Classification VIs in the Analytics and Machine Learning (AML) toolkit for LabVIEW. The model is saved into model.json using a number of features. How do I find out how much weight is each feature contributing to the final model?
Whether weight information of each feature can be extracted depends on the classification model.
If a linear model, i.e. linear regression model, is used you can find the features' weights by looking at the factor for each variable as shown in the block diagram below.
If a nonlinear model is used, like SVM or NN, it becomes more complex to extract this information because a lot of transformation and calculation is done on the input feature. There won't be any obvious indicators of each feature's weight.
