Compare Several LabVIEW VIs at the Same Time
Updated Oct 11, 2018
  • LabVIEW Professional
I have many LabVIEW subVIs, and I want to compare all at once. Right now I am using Tools»Compare»Compare VIs to compare VIs one by one.  Can I compare all VIs with same names concurrently?
Use the Compare VI Hierarchies dialog box, available in the LabVIEW Professional Development System, to compare two hierarchies of VIs. LabVIEW compares any file with the same name in both hierarchies and categorizes them as being the same or different.
