Can I Use the USB 6001 To Acquire Encoder Inputs?
Updated May 3, 2018
  • USB-6001
  • Quadrature Encoder
  • LabVIEW Base
  • LabVIEW Professional
I have an encoder that I would like to use to determine revolutions of a device as well as position and direction. Can I use a USB 6001 to do this?
As the USB 6001 only has one onboard counter, it is not recommended to attempt to use it to perform encoder acquisitions. You will need at least two counters on your DAQto use an encoder to determine not only rotations, but position and direction as well.
