Configure 9212 Module to Use High Speed Timing in LabVIEW
Updated May 11, 2023
  • NI-9212
  • LabVIEW NXG
I have an NI 9212 module, and I noticed that it has high speed timing capabilities. It appears the default timing mode is High Resolution, but I would like to change this setting it to use High Speed timing instead. How do I configure the module to use that capability?
The steps to change the ADC Timing Mode property either manually in NI MAX or the DAQ Assistant, or programmatically in LabVIEW and LabVIEW NXG are described in the Knowledge Base article How Can I Sample at More Than 2 Hz with My NI 9212, 9213, 9214, and 9219?
