Number of Parallel DAQmx Tasks on NI Multifunction Devices
Updated Jul 8, 2026
  • Multifunction I/O Device
  • I have a PXI/PXIe DAQ, PCI/PCIe DAQ card or a USB DAQ device (63XX, 62XX, 61XX and 60XX Series devices). How many DAQmx tasks of each kind can I run simultaneously on the same device?
  • I receive Error -200262 when trying to run the a Current Output On Demand Task with multiple channels on different devices.
In a multifunction DAQ device, the total number of possible concurrent tasks depends on whether you are running tasks that use hardware timing or software (on demand) timing †.
Hardware-Timed Tasks
Hardware-timed tasks require timing information from the System Timing Controller to use for sample clocks, reference clocks, triggers, etc. The following table illustrates the number of hardware-timed tasks available to the user.
# of Tasks per Device
Analog Input1
Analog Output1
Counter InputN††
Counter OutputN††
Digital Input1
Digital Output1
Software-Timed Tasks
Most software-timed tasks do not require a signal from a System Timing Controller in order to run. Software-timed means the host computer is controlling how often a sample is read from or written to the module.
Software-Timed (On Demand) Tasks# of Tasks per Device
Analog Input1
Analog Output1 Task for each AO channel†††
Counter InputN††
Counter OutputN††
Digital Input1 Task for each digital line capable of Digital Input
Digital Output1 Task for each digital line capable of Digital Output
Note: Some digital output devices require reserving and starting each DAQmx task in a specific order. If DAQmx Start Task is producing error -201133, see Error -201133 in LabVIEW™ When Running Multiple Digital Output DAQmx Task .
† It is possible to have Hardware and Software tasks running simultaneously, considering the maximum number of tasks for each timing mode.
††The number of counter tasks is always limited by the number of counters you have. Depending on whether you are using a counter task that uses multiple counters (like measuring frequency using the two counter method), you may be restricted to fewer counter tasks.
††† For 67xx cards, the number of DACs may differ. Refer to the documentation of each device to find out more. The number of parallel tasks can be calculated by dividing the number of channels by the number of DACs in the device.
Multiple channels can be combined in one task using channel expansion. The options and methods available for doing so will vary slightly from device to device. Please refer to the "Related Links" section below to learn more.
