Print and Export Menu Commands are Disabled in NI Multisim or NI Ultiboard
Updated Jun 13, 2025
  • Multisim Base
  • Multisim Education
  • Ultiboard Student
I want to print and export my circuit but the print and export commands in the File menu and the icon on the top toolbar are disabled. How can to fix this issue?
The print and export option is only available on activated versions of Multisim and Ultiboard. You are unable to print or export because you are running an evaluation version of the software.
To activate your software you have to have access to a valid serial number to generate an activation code. For further information on the specific process for software activation, refer to theĀ License Setup and Activation.
