Disable Auto Grow Property of Structures in LabVIEW
Updated Jan 22, 2021
In the block diagram, when I move variables inside a structure, the objects and structures expand. How can I disable the auto-resizing property?
This article describes different ways to disable the auto-resizing of structures depending on the scenario.
  • To turn off auto-resizing for all the new structures, go to Tools » Options » Block Diagram and uncheck the Place Structures with Auto Grow enabled option.
  • To disable auto-resizing only for a specific structure, right-click the structure and deselect Auto Grow from the shortcut menu.
  • To programmatically disable auto-resizing for all the existing structures in your LabVIEW project, use the Turn Off Auto Grow Using LabVIEW utility.
