Use 2 and 3 Wire Current Sensor with NI 9208
Updated Apr 24, 2023
  • NI-9208
Can I use both 2 wire and 3 wire current sensor types with the NI 9208 module?
It will depend on the wiring of the sensors but if it follows the conventional wiring mentioned in the NI 9208 Getting Started Guide, it will be possible to use both types on the same module.
