Align Display Object Layout in DIAdem REPORT Layer
Updated Mar 27, 2020
  • DIAdem
I am having difficulty in align display object of DIAdem REPORT layer. The frames that I had drawn in REPORT layers are not align in a straight line. Kindly referred to image below.
To adjust the layout easily, there is a Grid function provided at the function bar of REPORT layer. This function helps user to align display objects in REPORT layer of DIAdem. Grid Interval can be adjusted at Settings > Layout Setup > Layout Parameters...
After click on the Grid, you can start to move display object in REPORT layer easily. Below is the result after the adjustment.
Grid will not be useful in align display object if the display object is too big and will extend beyond of the worksheet after align. The only workaround at the moment would be resize the display objects to other appropriate size so it will not extend beyond worksheet after align then realign them.
