How to Measure Phase Shift in InstrumentStudio™
Updated Oct 7, 2020
  • PXI-5114
  • PXI Oscilloscope
  • InstrumentStudio
I want to measure phase shift between two signals in InstrumentStudio™.
There is no built-in option in InstrumentStudio™ for phase shift measurement.
However, you can use the Delta Time measurement to calculate the time span from when the first edge of the waveform crosses the Mid reference level until the second edge of the waveform crosses the Mid reference level, where the second edge is the second channel.
You can calculate the phase shift using this formula:
Phase Shift = (Delta Time between signals/ Wave period)x360
where the two signals have the same frequency.
