Print Measured Values in NFC Forum Test Report
Updated Oct 7, 2019
  • Micropross Accessories
When I use the NFC Forum Test Suite, I generate a report that lists the tests performed and the pass/fail verdict for each test case. However, I would like to see the actual measured analog values, such as LMA. How do I access this data?
After clicking on GENERATE REPORT in the main test suite window you will encounter the report configuration pop-up. The Advanced option tab contains a slider labeled "Test case to be include log in the report". Move this slider to the on position and the analog values will be included in your report.
