Convert NFC Forum File from MPECC to XML
Updated Oct 7, 2019
  • Micropross Accessories
I would like to convert my PICC's MPECC file to an XML document. Can I do this?
MPManager already stores the PICC ICS data in XML format. In MPManager, click on "Save As" while on the ICS/IXIT tab to save the configuration.
You can save the file format as either the default, .mpecc, or as .xml. In either case, opening the file in Notepad reveals a document in .xml format.
