Error 61060 When Using FPGA in VeriStand
Updated Jun 28, 2019
  • VeriStand
When I deploying system definition that uses I/O personalities for FPGA created with NI VeriStand FPGA-Based I/O Interface Tools , I receive error 61060 :
Error code:61060
Error Message:LabVIEW FPGA: The Wait on IRQ method timed out before the specified interrupt was received.
There are two possible solution for this error:
  • Check the naming of the .lvbitx file referenced in the .fpgaconfig file.
  • Make sure that in your custom FPGA VI, the number of the packets you read from the DMA Write match the iteration number. Check the number of packets for DMA_Read in the .fpgaconfig file as well.
