What Type of Transport Protocol Is Used for Ethernet/IP Communication?
Updated Jun 26, 2019
  • NI-Industrial Communications for Ethernet/IP
What type of protocol is used for transport layer of Ethernet/IP?
For Ethernet/IP, there are two communication types: implicit messaging and explicit messaging.
For implicit messaging such as I/O data messaging, Ethernet/IP uses UDP (User Datagram Protocol) as its transport protocol.
On the other hand, Ethernet/IP uses TCP (Transmission Control Protocol) as its transport protocol for explicit messaging.
In LabVIEW, functions in Industrial Communications >> Ethernet/IP >> I/O Data palette are used for implicit messaging, and functions in Industrial Communications >> Ethernet/IP >> Messaging palette are used for explicit messaging.
