이 내용은 고객님의 설정 언어로 확인할 수 없습니다
Upgrading NI Volume License Manager (VLM)
Updated May 1, 2025
  • Volume License Manager
  • I need to upgrade the version of NI VLM 3.X on our server due to compatibility issues with NI License Manager 4.4. How do I do this?
  • How do I upgrade NI VLM 3.X or later version to a newer or latest version?
If you are upgrading from NI Volume License Manager 3.x or ealier version to the latest version or you are moving to a new server, refer to the steps in Migrating NI Volume License Manager (VLM) to a New Server
Otherwise please follow the below steps:
  1. Although it may not be needed we recommend you make a backup of your server's settings before performing the update. See Creating an NI VLM Backup for instructions.
  2. Download and install the latest version of NI VLM (see Related Links for download page). You do not need to stop the server, or uninstall the older version of NI VLM first. The installation of the later version of NI VLM will overwrite the current version installed.
  3. Start NI VLM and ensure the server is running.
Upgrading NI VLM should have automatically caused your configuration and license file to be integrated with your new version of NI VLM. However, if there was an issue finding these files during upgrading, you will see the Getting Started Wizard in Step 3. If prompted for your license file you can use your existing license file. You do not need a new license file. If prompted for Import Settings select Import settings from a previous NI VLM 3.x installation, and select the Backup created in step 1.
Any users/computers that have previously checked out a non-concurrent network license will still have access to the software during the upgrade through the automatic 14-day backup license that will be issued when the server is inaccessible. Any users/computers using concurrent licenses will temporarily lose access to licenses.
If you are upgrading from VLM 2.X you will need to follow a slightly different process outlined in Upgrading NI Volume License Manager (VLM) Version 2.x to 3.x.
