How to Convert String Cluster Array to String Array?
Updated Apr 3, 2023
  • LabVIEW 2018
I have an array made of clusters; these clusters contain strings, as it can be seen in the following image
How can I convert this array of clusters to an array of strings?
To convert this array of clusters into an array of strings, you can use a For loop and a Unbundle by Name function.
The result of this code is the expected array of strings
Also, this code can be used for higher dimensions with a smaller modification, therefore, for a 2d array of clusters as input:
You can use this code
The output of this code is the expected 2d array of strings
