Make sure NI PSP Service Locator is running successfully. The account being used to allow the service to run may be invalid. You should check with your IT department to get valid login information.
As a workaround, run the service locally. To do so, navigate to Windows Services, right click the
NI PSP Service Locator and select
Properties. Select the
Log On tab and choose to use the
Local System Account. This may require Admin rights from your IT department.
