Archived:Programmatically Clearing Charts or Graphs in LabVIEW NXG
Updated Apr 28, 2023
  • LabVIEW NXG
When I use LabVIEW, I can clear chart by property node. When I use LabVIEW NXG, I cannot find it. Can I clear chart programmatically in LabVIEW NXG?
You can clear chart or graph in LabVIEW NXG by Clear Data function. You can find it in User Interface >> Panel Manipulation >> Graph palette.
You have to use chart or graph's reference for Clear Data function. The reference can be created by property pane for each chart or graph indicator.
