- MPMANAGER 3.6.4 and later
Click on FILE menu then on GENERATE LOG FILES ARCHIVE.
- MPMANAGER 3.6.3 and earlier
C:\ProgramData\Micropross\MPManager\<Version>
C:\Users\<User>\Documents\MPManager
On The execution Log, click on the Export Log Button. Then select where you want to save the .txt file.
<Test Suite>\Test Suite Traces\<Session> (normally default)\Analog Captures\Test Cases (or Setups depending on issue)
For deeper analisys, please send thos files to mp-helpdesk@ni.com
