Source and Destinations Missing in Routing Tab of NI MAX Test Panels
Updated Nov 26, 2020
  • PXI-668XH
  • PXI-6683
I'm trying to create the routes named in Configuring GPS Synchronization with the NI PXI-668x Timing and Synchronization Module but Oscillator and BoardClk are not available in the drop down menus. How can I make these routes?
You can manually type any valid Source or Destination. Valid routes can be found in the Device Routes tab from the bottom of the main NI MAX (Measurement & Automation Explorer) window.
