LabVIEW SoftMotion is no longer supported as of June, 2021. If you are designing a complex motion system, NI recommends considering an NI Partner or other third-party motion integrators to better assess application needs and solutions. Some possible alternatives are listed below.
Recommended Alternatives
- Use third-party controllers that can interface with NI products via serial or ethernet:
- Serial control with a LabVIEW API
 - Serial control without a LabVIEW API
	 - Use NI Digital I/O C Series modules and create all motion control code for use on an FPGA
 - Use EtherCAT drives with the NI Industrial Communications for EtherCAT driver instead of SoftMotion. This method would use the controller's EtherCAT command set to program the controller rather than SoftMotion axis and commands.
Note: an NI Partner is a business entity independent from NI and has no agency or joint-venture relationship and does not form part of any business associations with NI.
