CANopen Multiplexed PDO Feature Support
Updated May 12, 2025
  • CANopen Library Toolkit
  • NI-Industrial Communications for CANopen
  • What is the MPDO feature of the CANopen?
  • Does the National Instruments support the this feature of the CANopen?
Multiplexed Process Data Objects (MPDO) provide direct access to the objects of an application within a CANopen device. They are used to perform real-time transfers of small blocks of high priority data
Each MPDO message must contain one Communication Object-Identifier (COB-ID), index and subindex and two bytes of data.
National Instruments currently does not support this feature.
