How Do I Connect a Computer with Only One Ethernet Port to a cDAQ-9185
Updated Jun 13, 2019
  • cDAQ-9185
My computer only has 1 ethernet port which I need for connection to the internet. How can I connect to the connect to my cDAQ-9185 at the same time?
There are 2 methods to connect your device to a computer with a single ethernet port:
  • Use a router to enable you to have multiple ethernet ports.
  • Use a network port on the same subnet as your computer. Further information on how to set this up can be found here.
