Converting HTML to PDF Using LabVIEW
Updated May 13, 2025
I have a HTML file that I want to convert into a PDF. How can I do this using LabVIEW?
How can I convert a HTML to PDF without changing the formatting?
HTML files can be opened directly into Microsoft Word. This will ensure that the formatting does not change.
By using the code below, you can temporarily open the HTML file with Microsoft Word and make use of the export to PDF feature.
After the export has been completed, LabVIEW will close Microsoft Word.
Note: To use this method, you will need to have access to the LabVIEW Report Generation Toolkit and Microsoft Word. The LabVIEW Report Generation Toolkit is included with LabVIEW Professional 2014 and later.
