NI PXI 8461 is a 2-Port, High-Speed PXI CAN Interface Module, which can only be used with the
NI-CAN driver. It is not supported with NI-XNET drivers.
To get started with the PXI 8461 module in NI VeriStand, follow the steps as mentioned:
1) Install a compatible version (with NI VeriStand) of
NI-CAN driver.2) Open
NI MAX and click on
Tools->NI-CAN->RT Hardware Configuration.
3) Select the connected RT Hardware and put the correct port settings as per you need namely Baude rate, Termination, Database Files etc. in the Configuration Dialog Box.
4) Now, open the
System Definition File and manually add the CAN port with the same name as NI MAX.
